Old 02-04-2011, 05:29 AM   #1
rudy16
Exclamation wich fuel pressure regulator should i get?
i just bought a walbro 255 fuel pump. my friend told me that i need a fuel pressure regulator for this pump. but i dont know witch one to get and how to install it. can anyone help?
rudy16 is offline   Reply With Quote
Old 02-04-2011, 12:08 PM   #2
The stock regulator should be just fine assuming that you are running the stock injectors & rail. If you feel like purchasing a adjustable FPR Aeromotive has a good selection. The rails are different between the Turbo II & NA which model do you have? The NA rail the FPR is bolt on by 2 bolts. You could have some one make you an adapter, you could have someone drill & tap the stock rail for a fuel fitting or banjo bolt. Then there is always the choice of buying an aftermarket rail with provisions for an aftermarket FPR.
You can buy an adapter like this from HKS, SARD or Treadstone:
The Turbo II rail is set up differently, if I remember right the regulator is welded on.
Old 02-04-2011, 02:21 PM   #3
rudy16
ohhh ok. yea i have a non turbo. were can i get that adapter?
Old 02-04-2011, 07:28 PM   #4
Well there's a few different styles. The one above has a male AN fitting, some have a barbed nipple & some have a female end. You can Google Fuel pressure adapter, but I will give you one link.
http://www.frsport.com/SARD_Fuel_Pre...PR_p_1361.html
Old 02-04-2011, 10:50 PM   #5
rudy16
thank you very much! its just what i need.
Old 02-05-2011, 03:05 AM   #6
No problem man, BTW welcome to the forum.
Old 02-05-2011, 05:00 PM   #7
rudy16
thanks.
Old 04-23-2011, 12:24 AM   #8
shannonspeelman1231's Avatar
shannonspeelman1231
what about a turbo
shannonspeelman1231 is offline   Reply With Quote
Old 04-23-2011, 12:41 AM   #9
The turbo rails would have to be modified or run aftermarket rails.
Old 04-23-2011, 12:43 AM   #10
shannonspeelman1231
guess i will start lookin cuz i wanna run 720cc i already have the upgraded fuel pump in it
