Old 04-26-2004, 10:20 PM   #1
fc velocity
Default wireing harness
i have a 90 fc i was trying to start it the other day and my friend saw a spark coming from the harness nere the oil filter is there a way i can fix it or do i need a hole new harness thanx
fc velocity is offline   Reply With Quote
Old 04-27-2004, 12:39 AM   #2
Shaggy's Avatar
Shaggy
Well, you might be able to fix it, but if I were you, with anything electrical, I'd replace it. Thats what I would do.
Old 04-27-2004, 03:02 AM   #3
If it is a spark then it could possibly be an exposed wire which could be easily fixed with electrical tape. BUT since it is a spark and sparks can burn down your car I'd replace the whole harness.
Old 04-27-2004, 03:13 AM   #4
Shaggy's Avatar
Shaggy
Yep...you could just rig it with the taping of the wire..but change the puppy...unless you like to cook marshmollows with your burning car.
Old 04-27-2004, 04:22 AM   #5
fc velocity
thanx i am going to change it u know where i can get a good yet cheap harness
Old 04-27-2004, 05:10 PM   #6
I've never seen one aside from the ones Mazda themselves sell.
Old 04-28-2004, 02:46 AM   #7
2ROTORMOTOR
I dont think you may want to replace your entire harness for a wire... The only spark from around the oil filter I can think of is the starter wires.. Just replace those wires. There is a wire going to the oil pressure sending unit. but I doubt its that. Check what wire it is thats making the spark and let me know. No need in replacing the entire harness. When the harness is 14-17 years old the heat and oil residue tend to break down the plastic on the wires and that includes the connectors so be care full when disconnecting shit.. and if you can post a pic
Old 04-28-2004, 02:48 AM   #8
Jeremy
Send a message via AIM to Jeremy
You could call a few junkyards and find the year/model rx you have, and see if they have one thats been recked, or something... you can sometimes find a decent wireing harness out of old cars that still have plenty of life left in them, but, it might take some looking. I know the guys around here would just give it away for free if you took the time to find it and pull it out yourself, hey... its cheap!
Jeremy is offline   Reply With Quote
Old 04-28-2004, 07:16 PM   #9
fc velocity
ill put up a pic as soon as i can get a camra. every thing happened about six months ago i blow my clutch at 145 mph on the highway racing friends. i brought it to a shop to put in the cluch in, when they were done the trany was f*@ked. i had my landlord in the car to take him home did a smoke show and all of a souden my tack stopped working the light on the tack even stopped working but the car was still running i shut off the car at his house and it would not turn over sence that day.
Old 04-28-2004, 08:48 PM   #10
2ROTORMOTOR
aiight bro go ahead and post the pictures up...
