Go Back   Rx7 Forum and Owners Club > Preferred Vendors > RockAuto
RockAuto RockAuto ships thousands of auto parts from over 200 manufacturers to customers on every continent except Antarctica-including APO/FPO addresses. The RockAuto catalog is updated daily with mechanical parts like brake pads and shock absorbers, body parts like bumpers and mirrors, interior trim like door handles and carpets, and major assemblies like steering gears, CV axles, engine long blocks, and complete transmissions.
Rx7 Performance Parts - Rx7 Accessories - Rx7 Transmission - Rx7 Suspension
Old 02-10-2017, 04:12 PM   #1
RockAuto's Avatar
RockAuto
Preferred Vendor
Smile LED Bulbs at RockAuto.com!
Car restorers know answers to the question,"How long does it take to replace an instrument panel light bulb?" range from "five minutes" to "I started taking apart the instrument panel two months ago, and I still haven't found that %!@# bulb!" Hard to reach bulbs and any other bulbs that you only want to change once, can now be replaced with new LED bulbs. Here are just a few benefits of using an LED bulb for your automotive lighting needs:
  • LED bulbs do not have a filament wire like incandescent bulbs, making them better equipped to withstand vibration
  • LED bulbs last longer, use less power and give off less heat compared to incandescent bulbs
  • LED bulbs typically give off more light and even come in multiple color choices
  • LED bulbs have fewer part numbers, making them more universal
While LED bulbs do cost a lot more than incandescent bulbs, this is less scary when you consider that many incandescent bulbs start at less than $0.25 at RockAuto.com. It could be worth $10 or even $20 to avoid disassembling an instrument panel a second time.
Find all types of bulbs, with choice of brands, at RockAuto.com under the "Electrical-Bulb & Socket" category for your vehicle.
RockAuto is offline   Reply With Quote
