Old 03-19-2011, 06:02 PM   #1
First you warm up the car, then remove hose @ ACV to air silencer and put thumb over ACV and increase rpm to 2K and see if air start coming.
Old 03-20-2011, 03:20 AM   #2
Duneratz00
Okay I took off the air silencer hose and put my hand in front of it. I didn't have a tachometer or someone to help me but I would say around 2800 it started shooting out air. Would that mean one of my check valves isn't working? If so would it be the one in the split air pipe or under the acv. Also the Haynes manual doesn't explain this system very well is there somewhere online that would explain it better?
Duneratz00 is offline   Reply With Quote
