Old 05-05-2010, 02:18 AM   #1
freddy junior's Avatar
freddy junior
Default Wire plug problem to ecu
Working on 86 rx7 that has 91 gtu motor and ECU. The 87 had no ecu. 87 Wire plug that goes to the right side of ecu won't fit. does anybody know if they sale converting plug or if anyone has a wire diagram showing plug for 87 & 91.
freddy junior is offline   Reply With Quote
Old 05-08-2010, 09:00 PM   #2
ECU has to match with engine and tranny. Why don't you go with EMS which eliminate the prob. Secondly I sure wouldn't want to use them 20+ year old harnesses if I can help it.
Old 05-09-2010, 04:03 AM   #3
freddy junior
Default Ems info need
EMS does this mean going curb, and elimate fuel inj, now do i have to use a manual fuel pump.
Old 05-09-2010, 04:26 AM   #4
How are you with following a elec diagram? You can always make your own harness
Old 05-09-2010, 05:16 PM   #5
freddy junior
thank you for the info, i'am alright looking at a wire diagram if i can find the right diagrams i need if not i will pull hole wire hernest out of 91 and put in 87 it will be the only thing i didn't change on the 87 yet.
