Old 04-29-2011, 02:57 AM   #51
rx7Noobie
Yeah i jus got the header in the mail today, the only thing im not sure about now is if i should replace the rest of my stock exhaust to 2.5 inch piping, maybe my stock piping after the header an hi flo car is gunna be restrictive
rx7Noobie is offline   Reply With Quote
Old 04-29-2011, 03:37 AM   #52
You can if you want, but at this point it's not needed.
Old 04-29-2011, 05:29 AM   #53
rx7Noobie
Niceee i just hope after i put my header on it still has a deep tone. and im gunna wait on putting the header on till i get some money for heat wrap i guess, do you think its worth waiting for or does heat wrap not make much of a difference?
Old 04-29-2011, 05:43 AM   #54
Heat wrap serves two functions. 1. Keeping heat in the header. 2. Helps with under hood temps & keeps heat off other components.
Old 05-04-2011, 05:28 AM   #55
rx7Noobie
Update: waiting on my $200 to buy heat wrap n magnaflow hi flo cat...
P.S: with 160k miles on my 13b what do you think my chances are for blowing my engine going over 90mph if i take it to the track?
Old 05-04-2011, 08:30 AM   #56
160k is a lot & any track time is added wear & tear so yes you would be increasing the chances. Not saying that it will let go, but going to the track os a situation where you pay to play. Sometimes things break or fail, so be prepared to fix.
Old 05-08-2011, 12:41 AM   #57
rx7Noobie
I tryed ripping the ebrake in an empty lot and it doesnt lock up the back wheels it just slows it down why is this?
Old 05-08-2011, 04:18 AM   #58
Possible that it needs adjustment! May I ask why you were yanking the E brake in a parking lot?
Old 05-08-2011, 04:57 AM   #59
rx7Noobie
Trying to enter a drift, & idk i tightend the ebrake it still doesnt make the rear lock up -_-
Old 05-08-2011, 06:12 AM   #60
Don't know what to tell you then. Should be working if the cable is adjusted correctly.
