Old 10-05-2011, 04:54 AM   #1
Default add coolent buzzer !!!
my add coolent buzzer will not stop buzzing. my coolent is fine the buzzer must just be broken or somthing.so were is the buzzer located so I can take it out and smash it with a hammer.
Old 10-06-2011, 02:51 AM   #2
Moderator
The sensor may be bad or could be a bad wire. I assuming you have checked your coolant levels, have you tried bleeding the system to make sure there is no air in there?
Old 10-06-2011, 09:23 PM   #3
I will try bleeding it
Old 10-10-2011, 08:49 PM   #4
bleeding it didnt work
Old 10-11-2011, 01:33 AM   #5
Moderator
What about the sensor, it could be bad.
Old 10-11-2011, 05:20 AM   #6
is the coolent level senser the one on top of the radeater?
