Old 12-13-2004, 06:16 PM   #1
rx7eatnhondas
Send a message via AIM to rx7eatnhondas
Default wont start please help
I am new to this and I have a 87 TII.I was driving it down the road and all of a sudden it cut off so i try to start it and it finally starts and idles at like 500-600rpms and vibrate really bad.Now it will just crank and act like it wants to start but it wont.
Any suggestions will be great?
MODS: streetport and polish, 3mm apexi seals, and a fuel cut defender
rx7eatnhondas is offline   Reply With Quote
Old 01-04-2005, 07:10 AM   #2
Sounds like a weak battery or crappy spark. Check your voltages and maybe replace your alternator with one from an FD
Old 01-12-2005, 12:07 AM   #3
Black Mantis
Is it possible that he blew the main seal. My father blew the seal on his 86'. The car vibrated and the rpms dropped extremly low. Couldnt drive the car past 50mph after that.
If thats the case, the whole motor has to come out just to replace that seal.
Black Mantis is offline   Reply With Quote
Old 01-12-2005, 07:21 PM   #4
If its the rear main seal just the transmission does, and front main seal then just the fan shroud and pulley assembly does.
Hopefully for you, its your alternator
Old 01-15-2005, 12:29 AM   #5
rx7eatnhondas
got it running but it idles at 500 and is smoking a lil and has no pomer like it takes like 15 seconds to get it to rev 5000.
Old 01-17-2005, 09:59 PM   #6
As I pm'd you and BkMantis has mentioned...I think your seals are goner.
Old 01-26-2005, 03:32 AM   #7
Seals. Yup.
Old 02-16-2005, 05:24 AM   #8
rx7eatnhondas
figured out that all it was were some bad Vac leaks
