Old 03-25-2005, 10:21 PM   #1
justinius7
Send a message via Yahoo to justinius7
Default sudden lack of power
Hello, new to the forum. ALthough have read many postings.
I have a 1988 GXL, have been second owner since 1993. I had the car in storage for 6 months. I recently picked it up and it seems as if there is huge loss of power as well as the fuel economy is only about 15 mpg.
The otherday i jumped on it and got smoked by a stock OLD miata, so i timed my 0-60 on my watch, takes about 12 to 15 seconds.
The car has 73k on it, does not smoke, and runs smooth. Except during warm up the idle jumps repeatedly between 1200 and 2000. Also if i apply very little preasure to gas pedal the idle will become irradic and driving in traffic becomes a challenge.
Most everything is stock. Any suggestions on where i should start testing, i do not see any disconned vacuum lines or sensors. Is this possibly a common issue and/or an easy fix.
justinius7 is offline   Reply With Quote
Old 03-27-2005, 07:56 AM   #2
You'll need to ck your vac lines first...And you should replace them as they are old.
I'm replacing my vac lines with Hose Tech silicone hoses.
Old 03-28-2005, 04:38 AM   #3
I think you've blown an apex seal. Check your compression.
Old 03-29-2005, 12:46 AM   #4
justinius7
Thanks,
I checked all the vaccuum lines, they are old so i will start taking on that task. Also after reading many of the forums noticed that the 5th and 6th ports are not opening. SO i've tapped off of the air pump.. but it now only stays open for about 3 seconds. Any idea's?
I still need to check the compression, but i do not appear to be smoking or burning any access oil.
Any other suggestions? Thanks again!
88 RX7 GXL
91 190e 2.6
03 C320 Coupe
Old 03-29-2005, 06:49 PM   #5
Ahh my bad, I read a different topic and responded to this one. Sounds like vacuum on this car. Doesn't hurt to check your compression anyways though.
Old 04-08-2005, 10:14 PM   #6
Psycho_Dad
Send a message via ICQ to Psycho_Dad Send a message via MSN to Psycho_Dad
lol blown a seal, didnt know eskimos were on this site =P
jokes guys
cheers
Psycho_Dad
'it could be worse, a woman could cut your penis off and toss it out the window of a moving car....'
Psycho_Dad is offline   Reply With Quote
Old 04-08-2005, 10:21 PM   #7
LOL... nice to see you back, man!
