Old 04-04-2006, 07:01 AM   #2
Welcome!
First thing I would recommend is to drain all fluids including tranny, brake, coolant, oil and drain your gas tank to prevent possible contamination.
Then, I would ck all vac lines (you should get it replaced with a quality silicone hoses like Hose Tech hoses), fuel lines and change fuel filter along with try to eleminate that exhaust leak.
Ck your grounding and ck battery cables (inside the wrap) for corrosion as it will increase resistance.
Try to remove carbon build-up by using ATF (you can find thorough procedure),
As it seem to have high mileage (unless it was rebuilt) I would drive accordingly.
I use HKS Megaflow 200mm intake filter, Atkins oil filter, and Royal Purple oil.
And then, get it tuned properly.
AND, I ck my fluids everytime before I start. Type of oil you use depends on climate. I use 10-40w.
That's all I can think of at this time...
Enjoy your new ride!
