Old 01-09-2011, 07:45 PM   #1
Duneratz00
are you sure you dont mean the uper rad hose. and how hot did u get it cos that sounds like a blowen water seal . i would do a coolent presure test, and comp test will your at it
Duneratz00 is offline   Reply With Quote
Old 01-09-2011, 10:09 PM   #2
EastonH8
It was probably the upper radiator hose, it was just below the H before I turned it off. When I turn it over the coolant bubbles. I've been burping it to get the air out. I will see if I can get the pressure and comp test done soon.
EastonH8 is offline   Reply With Quote
